moonshadow
Nov 11, 2014Aspirant
apt-get -- Couldn't find package screen
Hello, I want to automate scripts for my Newznab installation on my ReadyNAS Ultra6 Plus using the screen command, but it is not available by default, and the apt-get command returns the error "Cou...
moonshadow
Nov 12, 2014Aspirant
Again, thank you for your earlier responses.
I was able to install screen once I uncommented the last line in /etc/apt/sources.list. However, when I try to run screen, it fails to open and returns the following error:
I am sure there is a simple fix but it eludes me. Is there a config file somewhere I can edit to fix this?
Cannot find terminfo entry for 'xterm-256color'
