moonshadow
Nov 11, 2014Aspirant
apt-get -- Couldn't find package screen
Hello, I want to automate scripts for my Newznab installation on my ReadyNAS Ultra6 Plus using the screen command, but it is not available by default, and the apt-get command returns the error "Cou...
moonshadow
Nov 12, 2014Aspirant
Also, I'm getting these annoying PHP5 errors.
This does not appear to be interfering with the Newznab scripts though.
The following packages have unmet dependencies:
libapache-mod-php5: Depends: php5-common (= 5.2.0-8+etch13) but 5.4.30-0rnx1 is to be installed
php5-mcrypt: Depends: php5-common (= 5.2.0-8+etch13) but 5.4.30-0rnx1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
