Gelangweilt
Jul 10, 2009Aspirant
bittorrent not working
Hello! my bittorrent downloads wont work. when i add a torrent via file or link the download wont start. actually nothing happens. can someone share some ideas where i should start looking for...
Fayez
Jul 12, 2009Aspirant
Hmm. Well, there are really only two scenarios that I think can cause this problem (note: I'm not a ReadyNAS expert, just a fellow user)... Either the trackers are down (or inaccessible) for your torrents, or the ReadyNAS can't access/"see" the Internet. Have you set up your ReadyNAS to send e-mail alerts? If so, are those working? (that would rule out the ReadyNAS not being able to "see" the Internet).
Try a well-seeded torrent such as one from: http://distribution.openoffice.org/p2p/
Good luck.
Good luck.
