Gelangweilt
Jul 10, 2009Aspirant
bittorrent not working
Hello! my bittorrent downloads wont work. when i add a torrent via file or link the download wont start. actually nothing happens. can someone share some ideas where i should start looking for...
btaroli
Jul 13, 2009Prodigy
If you search around you will find there have been a variety of complaints about the bundled BT client for a while. When it works it's pretty good. When it doesn't you're basically left gutting the entire config for the BT stuff and starting it fresh.
I have had significantly better luck and consistent behavior from the Transmission BT client, available in the community add-ons forum.
