Philip_77
Jul 14, 2015Aspirant
Bittorrent Sync for ReadyNas Duo v2 available?
Its seems to me that there are only 3 apps available to my REadyNas Duo V2, Radiator 5.3.7. Can this be true? Especially I would like to run Bittorrent Sync on it. I tried manually installing it, f...
RX
Jul 15, 2015Luminary
Philip_77 wrote: Not a great selection for 5.x. Can I upgrade to 6?
It is not possible to upgrade the firmware of your Duo v2 to OS6 firmware. However, if you plan to upgrade to a new hardware which is a ReadyNAS OS 6, then that would be a good choice for me.
Kindly check this link: http://www.downloads.netgear.com/files/ ... -RN700.pdf
