Philip_77
Jul 14, 2015Aspirant
Bittorrent Sync for ReadyNas Duo v2 available?
Its seems to me that there are only 3 apps available to my REadyNas Duo V2, Radiator 5.3.7. Can this be true? Especially I would like to run Bittorrent Sync on it. I tried manually installing it, f...
Jul 15, 2015Guru - Experienced User
The RN100 and RN200 series are closest to what the OP has now. They are also part of the OS6 line, but are listed under "home" products. http://www.netgear.com/home/products/co ... dynas.aspx
Unfortunately the duo-v2 and the nv+-v2 had a short life, so there simply isn't much incentive for app developers.
