Barney_Gumble
Dec 29, 2011Aspirant
Calibre - E-Book Management Add-On
Hi, not sure if this is the correct place for this question, but it's my best guess! I was wondering if there was an Add-On for the Calibre E-Book Management doohickey? For those who don't know,...
banjopicker
Jan 06, 2012Aspirant
Calibre has a command line interface as well that would be useful to use on the ReadyNAS via ssh. This way you could setup cron jobs so that it could automatically create e-book versions of the magazines and newspapers that it supports.
Unfortunately, I cannot get the linux version of Calibre to install because it doesn't have a working version of bzip2, and when I try to install it I get the following:
And then when I try to install bzip2:
Can anyone help? Thanks.
BigBertha:/usr/bin/calibre# sudo python -c "import sys; py3 = sys.version_info[0] > 2; u = __import__('urllib.request' if py3 else 'urllib', fromlist=1); exec(u.urlopen('http://status.calibre-ebook.com/linux_installer').read()); main()"
Enter the installation directory for calibre [/opt]:
Will download and install calibre-0.8.34-i686.tar.bz2
Downloading calibre-0.8.34-i686.tar.bz2
100% [=========================================================================================================]
Downloaded 49198179 bytes
Checking downloaded file integrity...
tar (child): bzip2: Cannot exec: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
Traceback (most recent call last):
File "<string>", line 1, in <module>
File "<string>", line 285, in main
File "<string>", line 243, in download_and_extract
File "<string>", line 228, in download_tarball
File "/usr/lib/python2.6/subprocess.py", line 488, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '[u'tar', u'tjf', '/tmp/tmpm5r1AL']' returned non-zero exit status 2
BigBertha:/usr/bin/calibre# apt-get install bzip2
Reading package lists... Done
Building dependency tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
bzip2: Depends: libbz2-1.0 (= 1.0.3-6) but 1.0.5-6 is to be installed
E: Broken packages
