eton
Mar 07, 2014Luminary
Can ReadyNAS Duo v1 run Music Player Daemon?
Can ReadyNAS Duo v1 run MPD, Music Player Daemon? http://mpd.wikia.com/wiki/Install I tried the apt-get method (as simulation), with lots of unmet dependencies reported. # apt-get install mpd ...
eton
Mar 08, 2014Luminary
mdgm wrote: Those dependencies are way too great. Even if there is a way to solve those issues it would likely take a very long time.
You'd be better off getting e.g. a 312 and using that.
Thanks
I thought so too.
