Zapoteknico
Jan 18, 2017Aspirant
Cannot Find Transmission Folders and downloaded files
Hello all, I have just finished setting up my ReadyNas 10400. I installed Transmission 2.82 (the one availalbe in the Netgear Apps Catalogue) and so far I have been able to download Torrents with...
- Jan 18, 2017
Just call your share Transmission and create a folder in it called Downloads
Then in the Web UI show the path as /data/Transmission/Downloads
Apologies as I may have confused you re "/data/" as generally many share paths need that prefix
bedlam1
Jan 18, 2017Prodigy
Zapoteknico wrote:
I cannot find the default fodler where the files are in my ReadyNass and no Idea how to access them...
Open the Transmission webpage from your NAS, click the spanner (bottom left of screen) and a pop up will appear, on it the directory where torrents are downloaded to is shown (which you can change if required) . It needs to be a share on your NAS with a path begining with /data/
bedlam1
Jan 18, 2017Prodigy
It's a long time since I set Transmission up....... maybe it is User:admin and the NAS password?
