Zapoteknico
Jan 18, 2017Aspirant
Cannot Find Transmission Folders and downloaded files
Hello all, I have just finished setting up my ReadyNas 10400. I installed Transmission 2.82 (the one availalbe in the Netgear Apps Catalogue) and so far I have been able to download Torrents with...
- Jan 18, 2017
Just call your share Transmission and create a folder in it called Downloads
Then in the Web UI show the path as /data/Transmission/Downloads
Apologies as I may have confused you re "/data/" as generally many share paths need that prefix
Zapoteknico
Same result. The Nas password is the one that let me access the web gui that works perfectly downloading the torrents... The problem is that i cannot find the transmission folders anywhere :(
