Zapoteknico
Jan 18, 2017Aspirant
Cannot Find Transmission Folders and downloaded files
Hello all, I have just finished setting up my ReadyNas 10400. I installed Transmission 2.82 (the one availalbe in the Netgear Apps Catalogue) and so far I have been able to download Torrents with...
- Jan 18, 2017
Just call your share Transmission and create a folder in it called Downloads
Then in the Web UI show the path as /data/Transmission/Downloads
Apologies as I may have confused you re "/data/" as generally many share paths need that prefix
Zapoteknico
Fantastic. Thank you. It finally worked and as you stated
I created a folder in my share
I added /Data/ before the /share/folder
And it finally worked
Thank you very much
Thank you very much
bedlam1
Jan 18, 2017Prodigy
Great
As far as Remote Transmission goes it is possible to use User:admin
