Deeperdown
Dec 28, 2022Tutor
Cannot gain Admin Access NV+ (SMBv1 issue?)
I have just had a new laptop (windows11) and noticed that i cannot access my old NV+ NAS. I type in the IP address in files and i get an error code 0x80004005. I can see it in Netgear ReadyNas RAIDar...
Dec 28, 2022Guru - Experienced User
Deeperdown wrote:
I believe it is related to Windows 11 as it no longer runs SMBv1??
No. It is because the browsers have deprecated TLS 1.0.
More info on what to do about it is here:
Basically gain access with IE mode in Edge, or download an older version of FireFox (94.0.2 works).
You can then modify a file in the NAS to allow you to access frontview with http (not https) if you like. Instructions for that are in the linked thread.
FWIW, Windows 11 will run SMB 1/CIFS, but you do need to manually enable that in "turn windows features on or off".
Deeperdown
Jan 05, 2023Tutor
thanks for your prompt reply. I am not really very IT literate.
I have downloaded notepad++ but am a little lost on where i have to apply these changes. Is there an idiots guide?
i also notice the article states: "This change can coexist with a patch later on that installs TLS 1.2 (and of course it can be easily reversed)." Does this mean a patch will be issued in the future to correct this?
Thanks again!
- StephenBJan 06, 2023Guru - Experienced User
Unfortunately that is very unlikely. Netgear would have done it by now if they had wanted to. I don't know of any non-Netgear folks who would still have development tools.
- DeeperdownJan 09, 2023Tutor
OK thanks - is it possible to obtain an idiots guide of how to implement the code that was suggested?
