Mikaelwikner
Apr 11, 2012Aspirant
Cant change Transmission settings
Hi! This is my first post here since I got my Readynas Duo V2 yesterday. I´m trying to edit settings.json direct in the GUI of Transmission 2.50. Every time I change something it will go back to th...
JarnoG
Apr 12, 2012Guide
If Transmission is running, you should be able to edit most settings through the webGUI.
If you want to edit settings.json directly using Notepad++, you will have to stop the Transmission service, then browse to your NAS using CIFS. There should be a share called "addons-config". If the share does not show, then use your admin account to log in. Either the share then shows up, or you will have to go to the "c"-share and then there's a folder called "addons-config".
Go to addons-config, then the folder "Transmission", then to "transmission-daemon". Settings.json is one of the files in that folder.
