Mikaelwikner
Apr 11, 2012Aspirant
Cant change Transmission settings
Hi! This is my first post here since I got my Readynas Duo V2 yesterday. I´m trying to edit settings.json direct in the GUI of Transmission 2.50. Every time I change something it will go back to th...
JarnoG
Apr 14, 2012Guide
CIFS is the protocol that is being used when you browse to your nas via network places in windows explorer. I thought the addons-config folder was at the same place on the Duov2 as it is on the v1 and the Ultra's, but I might be wrong. There's probably someone around here that knows though..
