mallisette
Nov 03, 2014Aspirant
Connect error code: -300 ?
Hi, This has happened several times between two ready NAS's. The only fix seems to be to create a new backup session and run the initial backup over the local LAN before separating them and backing u...
DizzyD
Dec 08, 2014Aspirant
Same error -300.
Also tried to fix it with upgrading to 6.2. --> back up kept failing
New base without same LAN also fails. The website can browse from the replicate site and can see the number of files. No files are transmitted though.
BTW: after upgrade to 6.2 Readynas Remote (without using ReadyCloud) fails as well.
I will try to but them together in the same LAN and try it again.
- Jan 17, 2016Retired_Member
