cg5000
Jun 03, 2011Aspirant
Connecting to ReadyNas via ReadyNasRemote
Hi guys, Over the last week there were all sorts of errors being posted by user about the ReadyNas remote recent update. I just tried reinstalling ReadyNas remote - not getting the same errors I di...
sansmith
Jun 14, 2011Aspirant
My NV+ had v4.1.7 and RAIDar 4.3.1. I installed ReadyNAS remote per the instructions in the document. After I login and then select 'Connect to ReadyNAS' I do see a new folder in Windows Explorer called 'ReadyNAS Shares' and it is empty. I copied over a folder into the new ReadyNAS folder, and then logged out of ReadyNAS remote. After logging on again and selecting 'Connect to ..........' the folder is STILL empty.
When I select Start and type in \\nas I see all my allowed shares for that user, but still a blank 'ReadyNAS Shares' folder.
I tried uninstalling and reinstalling and I still had the same result.
Windows Vista 32-bit upgraded to Window 7 32-bit Home Premium
What is the problemo people???
