cg5000
Jun 03, 2011Aspirant
Connecting to ReadyNas via ReadyNasRemote
Hi guys, Over the last week there were all sorts of errors being posted by user about the ReadyNas remote recent update. I just tried reinstalling ReadyNas remote - not getting the same errors I di...
panjabi
Jul 21, 2011Aspirant
cg5000 wrote:
Cain wrote: I'm in the same boat as you guys..
I can connect to my NAS but do not see any files or folders.
You have to go into AddOns, Add New (Install ReadyNas remote)
Then go to add ons, installed, click on ready nas remote, and add the user that you want to have permisison to the share. This will make a small blue icon appear int hat blank folder...thats what gets you the ability to see your files. :)
Can you explain this a little more.
I've got latest addon installed. xxx.51
added user to remote bit.
remote pc software logs in and shows empty folder.
do I need to do anything to the fileshare itself on the NAS.
