cg5000
Jun 03, 2011Aspirant
Connecting to ReadyNas via ReadyNasRemote
Hi guys, Over the last week there were all sorts of errors being posted by user about the ReadyNas remote recent update. I just tried reinstalling ReadyNas remote - not getting the same errors I di...
tedblank
Aug 17, 2011Aspirant
I was having the same problem. After two frustrating days talking to support, it appears that the problem was in the ReadyNAS Remote server. As of last night (August 16, 2011) it was fixed on the server, but it also requires end users to do the following:
Go into your Manage ReadyNAS Remote app in RaidAR (under Services / Installed AddOns) , select Advanced, and select "Restart P2P".
After this, my empty folder was suddenly populated with all the shares and files on my ReadyNAS.
Good luck, let us know if it works for you.
PS - they have not yet told me if this problem might recur, or if the 'Restart P2P" workaround is something one should try as part of normal debugging. I've asked that question of their L3 support and they are supposed to email me back an answer.
Best of luck,
Ted
Best of luck,
Ted
