Darwinian
Sep 03, 2009Aspirant
"Connection Failed" message on Transmission Web Interface
Transmission 1.73 had been working fine (on Safari browser 4.0.3 and Firefox) until today when I keep on getting ""Connection Failed" Could not connect to server. You may need to reload the page to re...
Snodlander
Oct 21, 2009Aspirant
Wow, something weird just happened.
I've been having issues with my ReadyNAS NV+ losing connectivity and narrowed it down to the PHP and Transmission add-ons (I think)
So I uninstalled them both then reinstalled Transmission and checked the Settings.Json file - it looked very normal.
Then I added PHP and found I couldn't access the Transmission interface.
I rechecked the Settings.Json file and found the following default settings:
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": false,
"dht-enabled": true,
"download-dir": "\/var\/local\/\/Downloads",
"encryption": 1,
"lazy-bitfield-enabled": true,
"message-level": 2,
"open-file-limit": 32,
"peer-limit-global": 240,
"peer-limit-per-torrent": 60,
"peer-port": 51413,
"peer-port-random-high": 65535,
"peer-port-random-low": 49152,
"peer-port-random-on-start": false,
"peer-socket-tos": 0,
"pex-enabled": true,
"port-forwarding-enabled": true,
"preallocation": 1,
"proxy": "",
"proxy-auth-enabled": false,
"proxy-auth-password": "",
"proxy-auth-username": "",
"proxy-enabled": false,
"proxy-port": 80,
"proxy-type": 0,
"ratio-limit": 2.0000,
"ratio-limit-enabled": false,
"rpc-authentication-required": false,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "{80e6fdedf72e3cce1ce7836f434e7e5c2913d71btAy7fWe1",
"rpc-port": 9091,
"rpc-username": "",
"rpc-whitelist": "127.0.0.1",
"rpc-whitelist-enabled": true,
"speed-limit-down": 100,
"speed-limit-down-enabled": false,
"speed-limit-up": 100,
"speed-limit-up-enabled": false,
"umask": 18,
"upload-slots-per-torrent": 14
I see that this issue can be resolved by changing the settings but I am curious as to why these have suddenly become the default settings?
"alt-speed-up": 50,
"encryption": 1,
"message-level": 2,
"peer-port": 51413,
"preallocation": 1,
"proxy": "",
"proxy-port": 80,
"proxy-type": 0,
"rpc-port": 9091,
"rpc-username": "",
"umask": 18,
