Darwinian
Sep 03, 2009Aspirant
"Connection Failed" message on Transmission Web Interface
Transmission 1.73 had been working fine (on Safari browser 4.0.3 and Firefox) until today when I keep on getting ""Connection Failed" Could not connect to server. You may need to reload the page to re...
Snodlander
Oct 21, 2009Aspirant
Sigh!
I just made the changes that you suggested in the previous post and could get into Transmission fine.
I then changed the "peer-limit-per-torrent" setting to 240 as I wanted to download a single torrent as quick as possible.
All was fine for a couple of minutes and then... I lost all connectivity to my NV+
The lights were all on and it looked OK but there was absolutely no Ping response.
I now have to power cycle via the power button and try and resolve.
If you can think of anything that may be causing this problem, or better still a solution to it, I would be very keen to hear about it.
Many Thanks.
OK, so just an update.
I changed the "peer-limit-per-torrent" setting back to 60 and it worked fine for about 6 minutes or so and then the same problem again, no connectivity, no Ping response.
HELP!!!!
Many Thanks.
HELP!!!!
