Darwinian
Sep 03, 2009Aspirant
"Connection Failed" message on Transmission Web Interface
Transmission 1.73 had been working fine (on Safari browser 4.0.3 and Firefox) until today when I keep on getting ""Connection Failed" Could not connect to server. You may need to reload the page to re...
chrisdus
Oct 21, 2011Aspirant
Hi all,
I have the same problem... I just purchased my Netgear Duo, disabled the built in Torrent client, and did a fresh install of Transmission 2.34 beta 4 on RAIDiator 4.1.8.
Observations:
- The webinterface will give the error message: "Could not connect to the server. You may need to reload the page to reconnect." after a while (this seems to be around 30 or 60 minutes after restart)
- Very high CPU and MEM intake seen via 'top' whilst running (with active downloads)
- When going in to the "Installed Add-ons" page after seeing the error message above, it seems that the deamon stops (green dot is no longer green) and I have to reload it
Would I be better off using an older version of the client, after all, this client is still called BETA?
Cheers,
Chris
My settings.json;
NetGear:/c/addons-config/Transmission/transmission-daemon# cat settings.json
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": true,
"blocklist-url": "http://list.iblocklist.com/?list=bt_level1",
"cache-size-mb": 200,
"dht-enabled": false,
"download-dir": "/media/BitTorrent/",
"download-queue-enabled": true,
"download-queue-size": 5,
"encryption": 1,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": false,
"incomplete-dir": "/c/media/BitTorrent/Incomplete",
"incomplete-dir-enabled": true,
"lazy-bitfield-enabled": true,
"lpd-enabled": false,
"max-peers-global": 200,
"message-level": 2,
"open-file-limit": 32,
"peer-congestion-algorithm": "",
"peer-limit-global": 240,
"peer-limit-per-torrent": 60,
"peer-port": 51413,
"peer-port-random-enabled": 0,
"peer-port-random-high": 65535,
"peer-port-random-low": 1024,
"peer-port-random-on-start": false,
"peer-socket-tos": "default",
"pex-enabled": true,
"port-forwarding-enabled": true,
"preallocation": 1,
"prefetch-enabled": 0,
"proxy": "",
"proxy-auth-enabled": false,
"proxy-auth-password": "",
"proxy-auth-username": "",
"proxy-enabled": false,
"proxy-port": 80,
"proxy-type": 0,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 2,
"ratio-limit-enabled": true,
"rename-partial-files": true,
"rpc-authentication-required": true,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "REMOVED",
"rpc-port": 8181,
"rpc-url": "/transmission/",
"rpc-username": "admin",
"rpc-whitelist": "*",
"rpc-whitelist-enabled": true,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": true,
"script-torrent-done-filename": "/c/addons-config/Transmission/email_alert",
"seed-queue-enabled": false,
"seed-queue-size": 10,
"speed-limit-down": 400,
"speed-limit-down-enabled": false,
"speed-limit-up": 20,
"speed-limit-up-enabled": true,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 0,
"upload-slots-per-torrent": 14,
"utp-enabled": false,
"watch-dir": "/c/media/BitTorrent/sources/",
"watch-dir-enabled": 0
Observations:
Cheers,
Chris
My settings.json;
"alt-speed-up": 50,
"encryption": 1,
"message-level": 2,
"peer-port": 51413,
"preallocation": 1,
"proxy": "",
"proxy-port": 80,
"proxy-type": 0,
"ratio-limit": 2,
"rpc-port": 8181,
"umask": 0,
