Darwinian
Sep 03, 2009Aspirant
"Connection Failed" message on Transmission Web Interface
Transmission 1.73 had been working fine (on Safari browser 4.0.3 and Firefox) until today when I keep on getting ""Connection Failed" Could not connect to server. You may need to reload the page to re...
mdekrijger
Mar 10, 2012Aspirant
Yeah, same problem here. I first removed the existing bittorrent client, and then did a fresh install on my readynas duo (sparc). I disabled it again and set the "rpc-authentication-required" on false. I enabled it again and it dies somehow after a few minutes.
Just did a tail on syslog and found out it consumes too much memory
Mar 10 17:30:07 Grotesmurf kernel: Out of memory: Killed process 8565 (transmission-da)
