garethjjones's avatar
garethjjones
Couchpotato and Sickbeard Woes after ReadyNas restore
I've just re-built my ReadyNAs, as I needed to exchange disks,and the new disks were smaller than the old ones. I backed up all of the data, and have now restored it using Rsync.
Before I restored the data, the REadyNas was updated, and all the old add-ons reinstalled. I use Plex, sabnzb, CouchPotato and Sickbeard, and Transmission.
I got Plex to work with my media files, after restoring the database. Sabnzbd appears to work OK - using ReadynasXtras SABnzbd_0.6.10-rnx86-0.5.1
But I can't get Couchpotatoe or Sickbeard to work - they just won't start.
Sickbeard is SickBeard_0.485.1-rnx-0.8.1
Couchpotato is CouchPotato_2.0.git120915-rnx86-0.4.0
I've uninstalled, and reinstalled Sickbeard - and I just get a message saying service didn't start.
Similarly for couchpotatoe - though when I try to uninstall it - it still remains in the Frontview pane. I've deleted /c/.couchpotato and /c/.cpserver - and it still won't reinstall, or uninstall.
I'd like to know where the logs for the services are, so that I can see why they're not starting.
I may want to uninstall these two add ins, and then install a more 'standard' install of both programs. Trying to debug this with much of the information on the web is quite difficult as the install seems to put things in directories which are 'non-standard'. I'm happy to go without the Frontview add-ins if I can get my service back to normal. It was running quite happily for a long time before I had to rebuild.
Any advice grateful received.....
1 Reply
  • Well, just spent £4.74 on a new set of Add-ons, and everything is now installed and working, and at the latest version.
    I appear to still have the Sickbeard DB, though not the search providers, so some work to be done here, and I'm sure I can get he details of my old config from the NAS backup - assuming I can work out which file I need to access.
    Phew. :)
ProSupport for Business
