milks
Jan 19, 2015Tutor
Disable SSH with a cron job
Hi someone is attempting to brute force SSH access on my ReadyNas Ultra2 from multiple IPs. This can be in the form of several hundred login attempts within a second at a particular time of day. ...
Jan 20, 2015Guru - Experienced User
You'd normally do it just in your router,there is no need to do it in the NAS.
When you said that you were using the NAS as a gateway, did you mean that there is no NAT router between it and the internet?
