milks
Jan 19, 2015Tutor
Disable SSH with a cron job
Hi someone is attempting to brute force SSH access on my ReadyNas Ultra2 from multiple IPs. This can be in the form of several hundred login attempts within a second at a particular time of day. ...
Jan 20, 2015Guru - Experienced User
There is a way to change the ssh port in linux generally, but that could possibly create issues for remote Netgear support. It's easy to find guides on this, but I think changing the forwarding is easier/safer.
If the NAT router is set up for remote administration, you can also leave the port unforwarded, and simply turn on forwarding manually when you need it. Of course you need a strong password on the router (and should use https for remote administration, not http).
I've seen similar automated attacks on well-known ports, and in my experience switching to a non-standard port usually resolves them. Fundamental security isn't changed (since the attack is still possible, just on a different port). But generally attacks like this are focused on well-known ports, where the application is easily inferred from the port number.
