boezeroen
Apr 17, 2011Aspirant
Downloading private bittorrents (from private tracker)
Hi, does anyone know howto download bittorrents from private trackers? i dont see any option in transmission. It work with public torrents though..... anyone? :(
Jemini
May 30, 2011Aspirant
boezeroen wrote: Hi,
anyone? :(
There are two facets you should consider about:
1.the allowed client list. You are required to use only a particular client(and also the minimal version) to access it
2.bittorrent for readynas dose not support a passkey in the URL of tracker which are widely used in PT
