dsm1212's avatar
dsm1212
Apprentice
Jun 02, 2014
dropbox on PRO6 broken
dropbox stopped working on my pro 6. I removed the addon and reinstalled from the last 0.9.7 rev I was given after the 64 bit fix a couple of years ago. It installs me right back to where I was. The "testing build rev says "Build:", current running build ends in .33. Dropbox.com says my account is linked, but frontview says its not and nothing will sync. I've deleted /c/.dropbox*, ~Steve/.dropbox* and still when I remove and reinstall it knows my config so I'm missing removing something. Is there another config file to remove?
steve
  • After the fresh install I see that /c/.dropbox-dist has v 2.8.3 in it, but frontview still shows 2.6.33. When I click on "Upgrade to latest" it says installation is in progress. From the shell I don't see anything running and apache-ssl seems idle.
    steve
  • I guess I was stumbling over browser caching. I don't know why I had to reinstall, but I got to the point where it's enabled and green and I changed a file and the change was replicated. So I'm back online and running 2.8.3.
    thanks
    steve
ProSupport for Business
