slaboure
Sep 01, 2014Aspirant
DropBox sync status
Hello, I installed the DropBox for-pay add-on. How can I query for the sync status? I found the dropbox.py file from Dropbox who is supposed to do that, but it only works with Python >=2.5, so I...
mdgm-ntgr
Sep 01, 2014NETGEAR Employee Retired
Can you provide a link to the script? It might be possible to make a few modifications to the script and get it to work.
Do you use the Global Dropbox or the user Dropboxes or both?
