el_patron
Apr 04, 2013Tutor
Dropbox: Update failed
Hi there, I installed the Dropbox add on and everything worked fluently... Until I tried to upgrade to the latest stable version 2.0.4 today. Then I end up with installed version: Null And the push...
el_patron
Apr 05, 2013Tutor
TeknoJnky wrote: I got the same recently, I just left it at whatever the stable was working, the update seems broken.
Well, it seems that I was too impatient... Finally everything is working. The update takes quite a long time to accomplish, but finally the next morning the things looked good. Then stopping the service, deleting directories, restarting and reconnecting to the dropbox, et voilà... it is working.
In the meantime I upgraded to 2.0.5 quite fluently...
Thanks for your support!
