Chris_S's avatar
Chris_S
Duo v1 DNS updater for enom.com?
Hi All:
I am using my old Duo v1 as a target for a remote backup. The target location only has a dynamic IP and I have been using the ddclient add-on on my Duo v1 to update DNS-o-Matic (i never could get the official dnsomatic add-on to work) which in turn updates enom.com which is hosting my domain. This set-up worked for over a year but now enom.com has implemented some changes and as a result DNS-o-Matic no can no longer update enom.com
Enom have published their requirements on how to update the IP address (http://www.enom.com/help/faq_dynamicdns.asp), is there a way to use a different add on or change the config file of ddclient so that I can update enom.com directly? Unfortunately my programming skills are quite limited, so I cannot use the c++ code myself.
Many thanks!
Chris
  • As a temporary work around, or for others that are looking for similar setup, I've been using http://www.dnsdynamic.org/ lately for a few hosts. It's a free service, and a simple shell script in cronjob can keep it updated.
    # cat /etc/cron.hourly/updateip.sh
    #!/bin/sh
    EMAIL=my.email@gmail.com
    PASSWORD=mypassword
    DOMAIN=myhostname.dnsd.info
    IP=`curl --silent http://myip.dnsdynamic.com/`
    curl --silent --user "$EMAIL:$PASSWORD" -k "https://www.dnsdynamic.org/api/?hostname=$DOMAIN&myip=$IP"
  • thanks for that, although I was hoping to use my own domain.
    For the not so competent users here: how do I get the script to run?
ProSupport for Business
