NV_v2
Jun 16, 2013Aspirant
Every Folder Has An ".AppleDouble" Folder in it
I Am running ReadyNAS Remote version 1.5.8 for iOS and Radiator version 5.8.3 (arm) on my ReadyNAS NV+v2, and recently on my iPhone I am seeing ".AppleDouble" folders appear in every subfolder within...
Ushman
Jul 21, 2013Aspirant
In case anyone is interested, I was able to fix this issue by downgrading my firmware back to Radiator 4.2.22.
Since the rollback, I have no longer had the creation of any .AppleDouble files despite continuing to access my NA via my Macbook Air.
And in case you would like to clean up the .AppleDouble file mess in a nice and quick way, I used a program (for OSX) called BlueHarvest (free trial that cleaned up my entire NAS of these files in about 15 seconds). After I cleaned up all the files I turned off BlueHarvest. So I have been accessing the NAS with OSX and no more double files.
So it appears this issue lies within 4.2.23, perhaps they fixed it with 4.2.24, does anyone know if 4.2.24 is also seeing the creation of these files? Or Admin, do you have any comments on this?
Cheers
Cheers
