gman1
Oct 19, 2009Aspirant
extplorer: invalid checksum
I'm trying to install extplorer. First of all, its post appears to have been updated to version 2.01, but the linked bin is version 1.2. When I try to install that, I get an invalid checksum error.
dbott67
Oct 19, 2009Guide
Are you downloading for the correct platform (i.e. sparc-based version for Duo, NV+, etc.)?
This is the sparc-based version (for NV+, Duo, 1100, X6/600):
http://www.readynas.com/contributed/super-poussin/eXtplorer_1.2.bin
This is the x86-based version (for Pro, NVX, 2100 & 3200)
http://www.readynas.com/contributed/super-poussin/PRO-eXtplorer_1.2.bin
If you are using the correct version, try rebooting the NAS and then re-installing.
As for the version numbers, I'm not sure about that.
