master64
Aug 08, 2011Aspirant
Help with install Drupal 7.7 / update from Drupal 6.22
Hi evereybody.. After some days of try and error..i obtain unfortunately only error.. :( The goal is: obtainig a Drupal7.7 installation ok on a NetGear Ready NAS Pro with 4.2.18. The 2 ways i ...
NEOS
Mar 15, 2012Aspirant
I had no success on this. I got stuck with the initial update. The update help says to update original directories the copy in the new ones, copy back the sites folder, and run the update.php. All my permissions must be wrong. I get the message "You don't have permission to access /drupal/ on this server." any ideas?
The bottom line is that the current Drupal bin is not up to date enough to deal with the current PHP plugin. On top of that, it doesnt seem possible to update from the bin version to the latest official site version. So currently the plugin offered cannot be used.
To be honest, help here or in the actual developer sites is absolutely crap. Not just for this plugin, but for all. I have had no end of problems with plugins for the Ultra, and if there are fixets, they are convoluted and long winded. I'm a software engineer, so i would hate to be in the shoes anyone else dealing with these nas boxes. I have found missing URLs to install help files which are crucial and PHP files that splash the OS. The whole site is so amateurish, and Netgear should get behind it and support it better.
