vspb
Mar 18, 2011Aspirant
How to completely remove the ReadyNAS Remote and leafp2p?
When you delete an add-on ReadyNAS Remote are running services leafp2p and permanently occupy 2% CPU. I'm not going to use the ReadyNAS Remote and I want to kill them. How can I do?
monneym
Nov 02, 2015Aspirant
I recently had an issue with filled up system disk. It was due to
ReadyNAS_Remote.log and LeafP2P.log file. They were both giga bytes in size all filled with
Parsing config
Error parsing config
Error starting application -5
Start state -1
Parsing config
Service not started
Error starting application -2
Start state 2
I need to get a handle on how to control this, at least I need to redirect the output to /dev/null instead of the log file so my system fs doesn't filll up.
Nov 02, 2015Guru - Experienced User
One possibility is that your NAS isn't set up to access the internet. For instance, it might have a misconfigured static IP addres or be missing a DNS server.
If you aren't using ReadyNAS remote, you can turn it off. That should eliminate the log messages.
