vspb
Mar 18, 2011Aspirant
How to completely remove the ReadyNAS Remote and leafp2p?
When you delete an add-on ReadyNAS Remote are running services leafp2p and permanently occupy 2% CPU. I'm not going to use the ReadyNAS Remote and I want to kill them. How can I do?
mdgm-ntgr
Mar 18, 2011NETGEAR Employee Retired
leafp2p is needed for ReadyNAS Replicate not just ReadyNAS Remote. You care enough about that CPU usage to disable leafp2p? There are some boot scripts for leafp2p you can find in /etc/init.d and /etc/rc2.d/
I don't know if it's safe to remove these scripts (or replace them with empty files) or not.
