vspb
Mar 18, 2011Aspirant
How to completely remove the ReadyNAS Remote and leafp2p?
When you delete an add-on ReadyNAS Remote are running services leafp2p and permanently occupy 2% CPU. I'm not going to use the ReadyNAS Remote and I want to kill them. How can I do?
pywong
Apr 25, 2011Aspirant
I think Netgear should have an option to disable learp2p because it opens one or two connections to some server over https.
Which maybe a security concern for some users.
