vspb
Mar 18, 2011Aspirant
How to completely remove the ReadyNAS Remote and leafp2p?
When you delete an add-on ReadyNAS Remote are running services leafp2p and permanently occupy 2% CPU. I'm not going to use the ReadyNAS Remote and I want to kill them. How can I do?
chirpa
May 30, 2012Luminary
Not true. If it is proved that someone broke stuff via SSH, sure. We can't be held responsible for someone breaking the RAID, then calling us for help to fix it. But simple tasks like this would not be an issue for support to help for warranty issues and other setup questions.
jck_co_im wrote: (Obviously with root access, Netgear will deny support for any problems related)
- monneymNov 02, 2015Aspirant
I recently had an issue with filled up system disk. It was due to
ReadyNAS_Remote.log and LeafP2P.log file. They were both giga bytes in size all filled with
Parsing config
Error parsing config
Error starting application -5
Start state -1
Parsing config
Service not started
Error starting application -2
Start state 2
I need to get a handle on how to control this, at least I need to redirect the output to /dev/null instead of the log file so my system fs doesn't filll up.- StephenBNov 02, 2015Guru - Experienced User
One possibility is that your NAS isn't set up to access the internet. For instance, it might have a misconfigured static IP addres or be missing a DNS server.
If you aren't using ReadyNAS remote, you can turn it off. That should eliminate the log messages.
