ScottChapman
Jan 26, 2014Apprentice
how to configure iStat on OS6?
I got iSTat installed and running. But launch button is not active.
It does day what port to use, and what the default password, question is, what is the URL?
I tried http://<NAS>:5109 but get a "null" back.
- doylmiGuideHi Scott - iStat requires a separate client application. There is no "URL", as it does not have a web interface.
For example, if you have an iPhone, you can purchase a client from Bjango:
https://itunes.apple.com/us/app/istat-2 ... 29458?mt=8
Alternatively, if you have an Android phone, you can leverage my application, NAS Utils:
http://bit.ly/1aDvkgR - ScottChapmanApprenticeRight, I have it installed on my tablet, when I run it and look at Telemetry(iStat) it reminds me that I need an add-on (which I have installed on my NAS) and then proceeds to tell me I need an iStat passcode, and to check my configuration...
doylmi wrote: Hi Scott - iStat requires a separate client application. There is no "URL", as it does not have a web interface.
FIVE Bucks?! Is there anything cheaper you could recommend?
(Sorry for hijacking thread slightly)- ScottChapmanApprenticeIt's free on the android. But my experience is above... No idea not to establish my "passcode"
Or stated different, there is no charge for the one I can't get to work! ;-) - doylmiGuide
ScottChapman wrote: It's free on the android. But my experience is above... No idea not to establish my "passcode"
No problem, please use the following steps:
[list=a:3hvn35tz]- Go to the main screen (the one that lists your NAS device(s)).
- Press and hold your finger on the one you want to update the passcode for.
- Click "Edit" when the context menu pops up
- Scroll to the bottom, and update the passcode
- Press save
I'll make sure this is clearer in the next iteration. Will probably prompt for the passcode iStat is detected, but the passcode is missing. - ScottChapmanApprenticeOK, I'll try that. Are you the author of the android app?
- doylmiGuideYes, I am.
doylmi wrote: ScottChapman wrote: It's free on the android. But my experience is above... No idea not to establish my "passcode"
[list=a:3c0klogw]- Go to the main screen (the one that lists your NAS device(s)).
- Press save
So, I see how to enter my passcode, but my question was really what is my passcode??? I do not know how to establish or otherwise determine what my passcode is... - ScottChapmanApprentice
[list=a:3ls9fup8]- Go to the main screen (the one that lists your NAS device(s)).
- Press save
Also, when I installed iStat on my NAS, I got a share (that appears to be empty) than is snapshotting ever hour. - doylmiGuideI can't comment on the share, but the "default password" that displays on the Apps tab is the passcode. I believe this is 12345. super-poussin is the maintainer for the iStat "app" for ReadyNAS if you have questions specifically regarding iStat.
