fayraz
Jul 16, 2009Aspirant
How to install NZBGET?
Hi, I have just received my ReadyNas Duo and want to install NZBGET so it can handle all my downloads. Is there a step by step guide I can follow on how to install?
fayraz
Jul 18, 2009Aspirant
lchapuis wrote: hi,
* first, download PHP addon viewtopic.php?f=47&t=21458
* install PHP addon in frontview --> system --> update --> local
* reboot your nas
* install NZGET addon viewtopic.php?f=47&t=21791
* reboot your NAS
* stop NZBget service in frontview --> service --> installed add-ons (uncheck the box and save)
* then edit the file nzbget.conf in \\nas_ip\addons-config\Nzbget to setup your newsgroup server parameters
* start NZBget service in frontview --> service --> installed add-ons (check the box and save)
* and launch the web ui with http://nas_ip/nzbget/
Installation Notes:
username is user
password is pass
files are downloaded in media share under nzbget/download
monitor directory is in media share under nzbget/download/nzb
I think it's complete :)
Thanks for the info, I am stuck on another problem.
I have installed OpenDNS Updater and I get to the line:
edit /c/addons-scripts/OpenDNS/opendns_updater and put your username/password in it
What do I do here, how do I get access to that directory is there anything extra I need to install?
