fayraz
Jul 16, 2009Aspirant
How to install NZBGET?
Hi, I have just received my ReadyNas Duo and want to install NZBGET so it can handle all my downloads. Is there a step by step guide I can follow on how to install?
ourdave
Sep 05, 2009Aspirant
Hi there,
I've had a good look through the forums, but I can't find the info I'm after.
I didn't think I was stupid where computers are concerned, but there seems to be an assumption that you'd know how to configure the conf file.
I took one look at mine, and thought "huh!".
I've installed the PHP add-on, I've installed NZBget, I can get in to the gui....but I've no idea where to put my file server details. Usually I use newsleecher to get stuff from Astraweb - but I just can't see how I enter that - either in the config, or in the conf file.
Can someone kindly point me in the right direction?
Cheers
Dave
Cheers
Dave
