fayraz
Jul 16, 2009Aspirant
How to install NZBGET?
Hi, I have just received my ReadyNas Duo and want to install NZBGET so it can handle all my downloads. Is there a step by step guide I can follow on how to install?
str4ybullet
Dec 01, 2009Aspirant
You also need unrar and par2 packages. You can install those via SSH. You need SSH access and apt-get addons, which you can get at the follow locations.
http://www.readynas.com/download/addons ... SH_1.0.bin
http://www.readynas.com/download/addons ... PT_1.0.bin
Code:
apt-get update
apt-get install par2
apt-get install unrar
-APT_1.0.bin does not work on NVX's; what do you suggest? Also, where does one get the par2 and unrar packages?
Thanks,
Josh
Code:
apt-get update
Thanks,
Josh
