fayraz
Jul 16, 2009Aspirant
How to install NZBGET?
Hi, I have just received my ReadyNas Duo and want to install NZBGET so it can handle all my downloads. Is there a step by step guide I can follow on how to install?
MichaelR64
Sep 19, 2010Aspirant
use Putty as a client to connect to your readynas tru SSH.
This is where you installed EnableSSH for.
You'll get a terminal window(resembles a dos box)
Type the mentioned apt-get commands in this window.
