fayraz
Jul 16, 2009Aspirant
How to install NZBGET?
Hi, I have just received my ReadyNas Duo and want to install NZBGET so it can handle all my downloads. Is there a step by step guide I can follow on how to install?
Cabamaru
Sep 19, 2010Aspirant
MichaelR64 wrote: use Putty as a client to connect to your readynas tru SSH.
This is where you installed EnableSSH for.
You'll get a terminal window(resembles a dos box)
Type the mentioned apt-get commands in this window.
I am using WinSCP. It has an Open Terminal command that I used and run the commands but it doesnt par/unrar. I also just tried Putty and run the commands again. It still doesn't work.
By chmod 777 I assume it means setting the permission to read, write and execute on the files?
I checked the log file and I get an "ERROR Could not start script: Exec format error". Any ideas?
Thanks for your replies
