fayraz
Jul 16, 2009Aspirant
How to install NZBGET?
Hi, I have just received my ReadyNas Duo and want to install NZBGET so it can handle all my downloads. Is there a step by step guide I can follow on how to install?
MichaelR64
Sep 19, 2010Aspirant
what editor did you use to edit the config files ?
I had something similar; turned out i had used simple Notepad under Windows.
It messed up the line-endings; after editing it with something like Notepad++ / ultraedit etc. you can save as Unix style.
The config file can be parsed proerly then.
