fayraz
Jul 16, 2009Aspirant
How to install NZBGET?
Hi, I have just received my ReadyNas Duo and want to install NZBGET so it can handle all my downloads. Is there a step by step guide I can follow on how to install?
Cabamaru
Sep 19, 2010Aspirant
MichaelR64 wrote: didn't really look into these files you listed here.
i followed exactly the steps listed here.
turned out my only problem was the line-endingns in the config file.
That doesn't show up if you paste it here, you'll have to look in the files yourself.
See if it has CR or CR/LF endings.
Open them with a editor that allows you to show the endings.
If they are not Unix style you will get the errors you mentioned.
I just checked using notepad++. All the lines have "LF" at the end. Is that the problem?
