fayraz
Jul 16, 2009Aspirant
How to install NZBGET?
Hi, I have just received my ReadyNas Duo and want to install NZBGET so it can handle all my downloads. Is there a step by step guide I can follow on how to install?
Cabamaru
Sep 30, 2010Aspirant
MichaelR64 wrote: thats funny: nzbget.conf has all cr/lf but unpak.sh has all lf.
But it still works...
Can't help you really i guess.
I know for sure this was my problem, after i saved it correct, it started working.
I got it working after all. Copied the code again from another thread, found two lines which were wrongfully set as comments corrected them and now it works great.
I can even watch a movie at the same time as the NAS donwloads another.
Thanks a lot for your help.
I agree with the previous poster, this NAS is not easy to set up unless you are happy to only use the very basic functionality.
