Bob245
Jun 03, 2019Guide
How to set Alert level for disk and cpu temperature on RNDP4000 OS 6.10.1
Hello everybody. I have a ReadyNas RNDP4000 with OS 6.10.1 with 4 x WDC 3Tb hdd. I would like to know the trigger value off "alert level" for disk and cpu temperature. It possibile to modifiy ...
Marc_V
Jun 03, 2019NETGEAR Employee Retired
Hi Bob245
It's not possible to change the values right now and cannot be done on the GUI but you may want to check on this idea submitted on the Ideas exchange board and add a Kudo to it or you may want to submit a new one here.
Hope this helps!
Regards
Bob245
Jun 03, 2019Guide
Hi,
ok no change permit, ok.
Then I would like to know the actual level of temperature that it start an temperature alert.
Thanks
