kamanwu
Jan 18, 2019Aspirant
I have a question about update legacy device (pro 4) to OS6
I have a legacy device (pro 4) currently running at 4.2.31. I know os6 is NOT offically supported by netgear.
I have read lots of posts in the fourm. I really want to update my device to os6, an...
- Jan 19, 2019
Since you are using OS6 on your pro4, would you please let me know which verison you are using? (the last version is: 6.9.5)
6.10.0-T272 (Beta 3)
Also, on the version you use, did you find any problems which you need manually fix it? or everything works by default?No problems
kamanwu
Jan 19, 2019Aspirant
I want to comfirm the steps in case I misunderstand something.
1, download premodified image. I will downlaod from: https://mega.nz/#!qXZh1SJK!602JWVyfl--TliZCHiP2F5IjRvhH_MGms83mPqjD8xE
2, do firmware update like I do before by using the downloaded file
3, NAS will auto reboot and update to the new firmware (I just need wait)
Question 1:
Someone mentioned optional step: : R4toR6_Prep_Addon.bin (26 KB). What's this step do? What's the problem if I did NOT do this step?
Question 2:
I know everything on the system will be wiped off. How about my RAID 1 disks? I believe I will remove these disks before I do the updgread. After that, if everything looks good, I just need put them back in order? Can the OS6 still read these disks? OR I need let OS6 format these disks (all data will be lost), and copy my backup data back to NAS after format?
bedlam1
Jan 19, 2019Prodigy
No problems
- kamanwuJan 19, 2019Aspirant
I have read the link you provided. BUT the it did NOT mention where to download these files.
I read the post from here : https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/OS6-now-works-on-x86-Legacy-WARNING-NO-NTGR-SUPPORT/m-p/897023/highlight/true#M50465
one post mention: Optional (do before step 2 below): R4toR6_Prep_Addon.bin (26 KB)
the other post mention: Download PREPR4TOR6_0.1-x86.bin
I think they mention the same thing. I just want to know why we need this addon, and why it is "OPTIONAL" ?
bedlam1 wrote:
I suggest you read this thread (it is for Pro 6) but equally applies to Pro 4
Upgrade Bios in particlar
- SandsharkJan 20, 2019Sensei - Experienced User
R4toR6_Prep_Addon saves you an extra step of havng to do a factory default -- it does it on it's own. And no, your plan to re-insert your old drives with data intact won't work. You cannot re-use any of the internal drives without re-formatting them with OS6.
- Sep 05, 2015Retired_Member
- Sep 30, 2022Retired_Member
