tfg
Feb 22, 2016Aspirant
Is it still possible to install the Replicate add-on for a RN2100?
Hey now! I am having an issue with a ReadyNas 2100 that refuses to show any apps under the 'Add-ons' section under 'Available'? I know support has been discontinued, does this mean after a factory de...
- Feb 24, 2016
Hi tfg,
Have you tried restarting the P2P service in both systems or units?
Kind regards,
BrianL
NETGEAR Community Team
mdgm-ntgr
Feb 22, 2016NETGEAR Employee Retired
The add-on is available from the Replicate portal login page: https://replicate.readynas.com/login/index.html
You can install the .bin file via Add-Ons > Add New in Frontview.
Welcome to the Community!
JennC
Feb 23, 2016NETGEAR Employee Retired
Hello tfg,
Welcome to the community!
I believe you are referring to ReadyNAS 2100 and not RN2100.
You may download add-ons for OS4 x86-based NAS from Add-ons for RAIDiator 4.2 (x86) article.
- StephenBFeb 23, 2016Guru - Experienced User
You'll end up redirected here: https://www.replicate.readynas.com/login/index.html There is a download link for x86 4.2 NAS on the bottom right.
But you will also need a license for replicate on the OS 4 systems.
