DW2016
Aug 30, 2016Follower
Mapping Network Drive for Windows
Hi, I've got my ReadNAS 31200 set up and working and I'm now wanting to create two levels of high level folder (or share) - one that only I have access to and one that my team of 3 have access to. I'...
Aug 30, 2016Guru - Experienced User
Your home share is showing up because the PC is presenting your user credentials to the NAS.
If you want to see what the others on the team will see, you need to use their credentials.
- JennCAug 30, 2016NETGEAR Employee Retired
Hello DW2016,
This FAQ might help you. Once you access the volume of the NAS, the computer remembers your login and keep using it until you disconnect from the volume. You need to disconnect from the NAS drives first to get other users connect and test or see if access rights you have set are working as expected.
Welcome to the community!
- JennCSep 02, 2016NETGEAR Employee Retired
Hello DW2016,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
